Mimaki JV3 leaking ink
levakbob
Hi, I would like to ask for help with my JV3. Overnight he leaked almost all black ink from both cartridges. The ink flowed slowly into a waste container. Does anyone have a similar experience? Thank you
SightLine
My thought is the pump since it went to the waste container. The pump should not allow ink to pass when sitting.
levakbob
I read somewhere that the tube should be at an angle so that there could not settle fluid. That the plastic on the pump that moves up and down has some significance? I wondered if it locking up the tube. A pump is not necessary to completely close ...
MARAD
Hi, do you know what a issue was with your printer ?
Hi, do you know what a issue was with your printer ? can you let me know, Thanks
MikePro
a pump is necessary to close the line. you most likely need to replace it, especially if its never been replaced before.... that machine is OLD.
the printer operates like a siphon, firing the ink as it flows through, and stops the flow when parks on capping station attached to line that is closed by the action of the pump.
