mimaki jv33 error message/fix
erikjem
need advise ,
running machine perfect, disconnect it due storm lights, when i turned it on again to start working bumps this errror msg !car (#01) cartridge m-- ,try to print and send a msg , an ink error ocurs, i have the refillable ink system by t way.
all comments are welcome !
thank you in advance
Erik
97GTB
From the Local screen hit enter to show ink levels, then hit the function key should give you what the actual problem is scroll up or down as there may be more than 1 issue.
