Mimaki JV5 error 53 Head High Origin Help!!
Discussion in 'Mimaki' started by Digilab2, Sep 18, 2012.
  1. Digilab2
    Digilab2 New Member
    13
    Aug 8, 2011
    Mexico
    Hello, my JV5 display the error 53, I changed the head up and down encoder strip, the linear encoder PCB and the problem persist, any new idea will be very welcome...
  2. Robert72
    Robert72 Member
    66
    Have you changed the capping Y position? If you get the parking Y position too much to the left, the gear which moves the printhead up and down will have problems to work.
  3. Tekkie1
    Tekkie1 Tekkie of Many Things
    98
    1
    8
    Apr 27, 2012
    Australia
    Yes make sure the gears on the right are meshing correctly and not missing due to the carraige not going over far enough.
    There is a test procedure for checking the head encoder that is in service mode only.
    There is also a paremter to adjust if the gears are not meshing correctly but it has been a while since I have done it...let me know if this is what is happeneing.
    Tekkie1:Big Laugh
