Most aggressive adhesive vinyl?
Discussion in 'General Signmaking Topics' started by Rooster, Jun 12, 2012.
  1. Rooster
    Rooster Very Active Member
    1,208
    1
    36
    Feb 22, 2008
    Edmonton
    I have a client who is using cut vinyl decals for their heavy equipment ID's and branding and we're having the problem of the vinyl not wanting to release from the transfer tape (medium tack). It's not the transfer tape being too aggressive, but the vinyl isn't wanting to stick to the surface.
    I've tried 3M and Arlon and neither seems better than the other. I think the issue may be that they're painting the equipment with a paint that has a fairly high silicon content to stop dirt from sticking to it.
    Is there anything that you guys know of that is a cost effective solution to this problem. Is there a lower cost vinyl than convex that is designed to stick to a low energy surface or one that has a silicone content to it?
  2. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    Arlon DPF8000
  3. Coloradosigns
    Coloradosigns Major Contributor
    8,003
    99
    48
    Sep 10, 2010
    Denver.
    this
  4. Circleville Signs
    Circleville Signs Very Active Member
    2,140
    11
    38
    Sep 30, 2009
    Circleville, OH
    I don't know about the 8000, but I just used the Arlon DPX6000 wrap vinyl and it was a nightmare. Adhesive was the most ridiculously aggressive adhesive I've ever seen on wrap vinyl. Ugh.
  5. jasonx
    jasonx Very Active Member
    1,244
    2
    38
    Aug 5, 2007
    Australia
    Now imagine that 10 times worse and you have DPF8000.
    You tack it and its stuck.
  6. pjfmeister
    pjfmeister Member
    213
    20
    18
    Dec 10, 2006
    Missouri
    Dpf 8000
    I used this on the roughest textured stucco surface you can imagine and the wrap held tight outdoors for 6 months before the edges started peeling....good stuff
  7. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    CONVEX! Merchant member
  8. FishnSigns
    FishnSigns Member
    129
    2
    18
    Jul 14, 2011
    Littleton, Colorado
    Don't use IJ35. It images great but the adhesion is fair at best.
  9. laserman70
    laserman70 Very Active Member
    1,269
    1
    38
    Dec 25, 2007
    usa
    oracal 3105ht
    very high tack
  10. FatCat
    FatCat Very Active Member
    1,876
    116
    63
    Feb 12, 2007
    Columbus, Ohio
    Yup, this stuff is very sticky as I just did my first job with it about 3 weeks ago. I was playing with it and it was even pulling out ink and dirt from the crevices and wrinkles in my hand.
    Will have to keep in mind about the Arlon stuff though...
  11. Pat Whatley
    Pat Whatley Major Contributor
    8,568
    79
    48
    Sep 29, 2003
    Wetumpka, AL
    Great stuff at removing all the hair from your hands and arms while trimming and weeding it.
  12. Gene@mpls
    Gene@mpls Very Active Member
    1,939
    69
    48
    Jun 17, 2003
    Blaine, Mn
    I hate printing it- the adhesive gets on the media hold downs.
  13. Graphics2u
    Graphics2u Very Active Member
    1,836
    1
    38
    Jan 31, 2007
    Iowa
    How does it get on the hold downs and which product?
  14. Mike F
    Mike F Active Member
    750
    1
    18
    May 11, 2011
    Another +1 on the Arlon DPF8000
  15. Rooster
    1,208
    1
    36
    Feb 22, 2008
    Edmonton
    Thanks guys, much appreciated.
    I'm going to give a few of them a try on some sample stock and see what fairs the best.
    I also found a very aggressive adhesive from FLEXcon that seems to be rated about twice as sticky as the arlon and oracal products.
  16. signage
    signage Major Contributor
    9,233
    30
    48
    Oct 5, 2005
    Penn
    Pitbull!
  17. Gene@mpls
    1,939
    69
    48
    Jun 17, 2003
    Blaine, Mn
    dpf8000
  18. x2chris7x
    x2chris7x Active Member
    584
    5
    18
    Oct 30, 2008
    Louisiana
    oracal 3105HT - extremely sticky
