Mounting a banner to the side of a steel building
treb5555
Good morning,
Wondering if anybody has a preferred method or bracket available to hang a 3' x 6' banner to the side of a rib steel sided building. I am thinking (with the building owners approval) of a angle bracket to tie the webbing to, but attaching the bracket to the building using the existing siding fasteners, to prevent needing additional holes in the building. Just checking for anything you guys have done or know doesn't work.
Thanks very much in advance.
smdgrfx
Fender washer and Teks screws...don't overthink it. When they are ready to remove it, just put some silicone in the holes left behind. It's not noticeable. If it were a high dollar building, it would not be a metal building....
OldPaint
OR......see ig there is EXISTING building screws.......that you can unscrew, put banner/fender washer.....and run bacl in existing hole. heres a note for ya: metal building are 36" wide.........so finding existing screws at 72" & 36"........aint hard to do!!!
Billct2
If they will be using additional banners in the future setting up permanent brackets like you suggest is a good idea. Paint them to match the building and put a little silicone in the holes to be sure they're sealed.
hehe
Pat Whatley
What OP said.
We've also taken the heavy duty D-link hangers from Lowe's, backed out screws from the building, then reinstalled the screws with the hangers on them. Gives them a permanent tie down point and does no damage at all to the building. Kind of like what you're wanting to do with the angle brackets. Should work out just fine.
