Moze are these any good?
GAC05
Quit buggin' me
As some may know I had an unfortunate run-in with my last set of earphones and noticed these while picking up some stuff at Home Depot:
Reviews are mixed. 10hrs on a charge sounds good and I just listen to audiobooks so sound quality is not number one on the list. Cost is reasonable enough (I get an additional 10% off as an expired DOD employee).
I don't need a set of $200.00 earbuds that will be 100% lost or destroyed before they wear out. As a fashion statement they will go nicely with the DeWalt drill & tape measure on my low-rise hip-hugger toolbelt.
Why not just duct tape your old ones and keep using them ?? Stop putting your earbuds in the food drawer and you'll be fine.
Moze
Precision Sign Services
I've never tried the DeWalt because they don't have great reviews. Same as BobM, I use the Aftershokz Air and love them. They're good for working in areas that you might need to be aware of surrounding voices or noises.
Andy D
I have had many different type of Bluetooth headsets, but the best by far are Mpow 059 Bluetooth...
Great sound, reception, tough, 20 hours long play time, comfortable & they're only around $30 on Amazon.
netsol
not duct tape but a bit of heat shrink tubing. all you need is the wife's hair dryer
GAC05
Quit buggin' me
Problem with heat shrink is I can't disconnect one of the earpieces to slide the tubing onto the wire to set it. I tried spiral cutting a piece of shrink and then hitting it with heat - it sort of worked but left gaps on each turn as it shrunk down. I think what I need is heat shrink tape - no luck finding any on island.
For now, I split the insulation off a larger wire and slipped it on like wire loom. A little cut down electrical tape on each end keeps it from opening and coming off.
I also have some liquid tape sitting around here someplace but it's green and isn't going to match my DeWalt tools at all.
netsol
heat shrink tape
https://www.cabletiesandmore.com/he...MI06ueqZqp6QIVSAiICR0_WAlTEAQYASABEgK1CvD_BwE
for example
if you can solder i can send you some tiny male & female connectors
snip in the middle. put heat shrink in place. option 2 is probably much more trouble than it is worth
cut wire short where it comes out of headset and solder a mini 3 conducter
male that will accept a 6' or whatever standard "radio shack" available cable
send it to me in nj, i will fix & send back to you
Texas_Signmaker
Very Active Signmaker
or....he could just buy a new pair like he was asking about and not look like a crack head with busted up headphones. Yall think too much, Happy Mother Days
