Need Help Mutoh spitfire
Mina
i need help when i turn on the printer the display dose not give me any data and all leds are turned on and no movement in the printer
what can i do for this issue
v0y4ger
The spitfire bears a relation to the Rockhopper I believe. They are known for display problems but are otherwise decent pieces of kit - back in the day - I’m afraid your course of action probably needs to involve a printer engineer at the very least.
Assuming your printer will have been standing a while, it’ll need a good service.
Good luck
P.s. could you use a bit of punctuation next time, just so you get your point across nice and clear
Terry01
With the info you have provided, I'm guessing you have had a mainboard failure. If you haven't had the right
hand cover off and unplugged the display and not reconnected it properly, that is the only thing left.
Do all the leds flash or are they showing as though the are all jammed on?? From memory there are half a dozen
or more leds on the main board, in a line, that give you indication to the fault when it doesn't show on the display
