My SP300V and its printing problem..
So I'm having problems with the printing of my SP300V.
This is the problem.
I turn my computer on and get flexi up and running. I get my design ready to go and then I turn on the printer.
After the printer turns on and get warmed up, I send the grafix to print.
It rips it and say it prints it. BUT it does not. I have to go turn the printer off and then on again.. After that it prints THEN anywhere from 1/2 to 3/4 of the way it stops printing, the head goes back into the printer and then it seems to lock up.
I turn the printer off again and then on. When it turns on it prints with no problem and as long as the machine does not sleep or get turned off for the rest of the day. It works fine.
any ideas on whats wrong?
Mason
Thats a tough one, You might try unistalling and reinstalling the software.. outside of that I got nothing
Sabre
It might be a bit of a grasp, but when was the last time you updated the firmware in your 300V? By "turning on", you're just using the sub-power button on the keypad and not the main power on the side, right?
Yes just the subpower. I have not updated the firmware since i got it.
Sabre
Firmware updates can be found here. But if you haven't done one before it might be a good idea to give your dealer a call and have him walk you through it. Again, I don't know if that would get you any further ahead on your problem, but it certainly couldn't make things worse.
high impact
This is grasping for thin air but worth a try if you have corrupted data in the printer memory:
Actually unplug the printer for a minute and allow the electronics to discharge. See if that makes a difference.
I looked and i think i'm up-todate because the printer was bought in 10-15-07.
Sabre
When you initially turn on the machine it will show what version you're running. 6.60 is the newest.
TresL
I had a strange issue kinda like this that turned out to be the USB port on the PC. Changed to another USB port and haven't looked back since...
Here is a pic of whats its doing. Now its messing up every print.
Robert M
Sp300v
Are you running Vista? I am having issues with Flexi 8.5 & Vista
Try running it out of Versaworks
