Need help with main board .
nanee
nanee
If I send my main board out for repairs will my info still be in there when I reinstall or will I have to reset it all ... I have no power so can’t get to my settings . I have vp 540. Or would someone have a working one just sitting somewhere ... thank you. .. any imput will help. Thanks
IsItFasst
From my experience it always came back with the information on there after the repairs. I just reinstalled and started it right back up.
premiercolour
Just a heaeds-up. VP540 mainboard is known for problem. You might want to give Ron a call. 323-351-8968.
netsol
I BELIEVE you only lose ALL info if non volatile memory is replaced.
at that point you need peck software or whatever to re-enter info
if system is reset and cmos battery removed some info is lost, but machine is not like it just came out of box. it depends on what is replaced
premiercolour
Tell us more about what's going on with the printer? What is it doing?
Matt Gatenby
I second this info after working in the IT hardware business for 25+ years...as long as the non-volatile memory, as well as the CMOS battery (an onboard battery usually a coin battery), are left alone then you shouldn't lose any settings
