Need help,
Scott767
Hi, having trouble.
I have an EPS file. When I import it to Flexi, I get the picture in the top left. That is the way I want to cut it.
When I go to cut it, I get the picture in the top right, just an outline.
If I select the image, I get the bottom picture. the redline with the black outline.
How do I make that a solid line , so I can cut it like the top left picture.
thank you.
RG
Try this. Select the image. Click "Arrange" at the top tool bar. Click "Convert stroke to Outlines."
stew1tx
Centex Wraps and Signs
additionally, you can also look in the rip menu and look at the options tab (v12 subscription) and in the left margin i bet you will see several different colors. Turn off the cut lines you do not want by clicking on the knife image again in the left margin to the left of the colors.
RG
Here you go. Maybe click the "Help" and then the "About" tab to see if your version is the Pro version.
