Need Quality Teardrop Flags
2B
Looking for a vendor that does Quality Teardrop Flags that will last.
just had a most unhappy end user leave the shop, where they had 3 of the of block out Teardrop Flags
Placed an order the end of August from a suggested vendor here, and the flags are failing at the highest point.
See image
The tip is double layered but the flexible rod is still going through.
Texas_Signmaker
Very Active Signmaker
I've noticed those type of flags fade fast. Once a business has them out for more then 3-4 months (and the city hasn't told them to take them down) they all start looking bad. I think because it's cloth that it attracts all the road grime. All the vendors I know that make them are cheap cheap cheap.
2B
The material used for the imprint and the imprint are good.
It is the sleeve material and stitching that is failing as seen in the photo.
nate, what life expectancy do you have on your flags?
Sent from my SAMSUNG using Tapatalk
