Need someone to convert file from CC to CS6
timstudio
Hi, I'm still working with CS6 but a customer has the file only in CC format. Could somebody convert this (simple) file for me to CS6?
If so please post your emailadres in a PM and I will sent you the file.
As a thank you i will plant a tree in the forest nearby my house!
Cheers.
visual800
whatever version of illy you have you should always be able to go down and read everything under you. However if you have illy 9 you cannot open anything above that but from 9 on down you should be (just as an example)
so what issues are you having?
