New ehow article on building a UV Exposure Box <<L@@K>>
jgproducts
hello all.
After much putting off doing I finally finished my vacuum topped exposure box. Could not afford a high dollar one so decided to build my own. Could not find any really good plans so I took a bit from here and there and put them all together. It has a rubber sheet top and works great. Better than I had expected it to.
You can just make the bottom part and skip the vacuum top to save afew bucks. It is pretty easy to build with the right tools. I have $265 in it but it is a lot cheaper than a $1500 or so unit. Check it out when you get a chance and let me know what you think.
http://www.ehow.com/how_5658060_build-screen-printing-exposure-box.html?shared=true
Joe
JG Products
d fleming
Excellent job! You will make a fine screenprinter. Necessity is most definitely the mother of invention.
jgproducts
Thanks,
Actually just getting back into it to do some decal sheets for Rc cars. Just knew there was a cheaper route to take.
I hope it will be useful to some who need the help.
Joe
32bantum
In the last 8 years I have replaced most of my equipment with bigger and better. Over in the corner of my shop is a large osb box with a glass top and a pond liner over the top. You guessed it!! My exposure unit!! I'll match halftones with the best of them from process to simulated process. If it works...don't fix it.
