NEW longer Ethernet cable?
Discussion in 'Roland' started by phototec, Oct 8, 2012.
  1. phototec
    phototec Very Active Member
    3,155
    22
    38
    May 23, 2008
    Belton
    I'm relocating my Roland SP540v to a different location, and want to run a NEW longer Ethernet cable, I know I need a crossover type cable, but not sure about it being CAT5 or CAT 6 and how long you can go, basically need to run about 60-70 feet.
    Just going from one computer to the printer, but might also want to add another computer, what would be the best scenario, if I decide to add another computer to the mix?
    I know nothing about networking.
    Thanks for any help.
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    15
    both computers and printer all on router or switch
    I believe max ethernet run is like 300ft so anyway you do it should be fine
  3. phototec
    3,155
    22
    38
    May 23, 2008
    Belton
    Where do you locate the router or switch (near printer), and does it need external power?
    What about the cable itself, CAT 5 or CAT 6?
  4. J Hill Designs
    15,549
    15
    cat6 offers faster bandwidth and less signal degradation and crosstalk.
    yeah switches/routers are powered..put it where it needs to go i guess?
  5. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    Cat 5 is fine, the printer is only 100Mb, Cat 6 is for Gig.
    Max distance is 100 Meters or around 330 feet.
  6. 34Ford
    34Ford Member
    133
    If your motherboard has two ethernet ports like mine you dont need a router.
