Newbie on VS640
WrapYourCar
Hi Guys,
I have an urgent job i'm trying to color match a certain dark aqua/navy color, and my Magenta ink shows an exclamation mark "!", would this be altering the output of my prints? in other words if a printer is low in ink on a certain color does it change the output or does it know never to let it function when it's too low? thanks!
WrapYourCar
another question, i was told when i purchased my printer, when printing in "HIGH QUALITY MODE" it would reduce ink consumption, is this true? it sounds incorrect.
scuba_steve2699
It will stop printing before the cartridge runs out. Do not worry, it will not affect your colors as the machine will not let the ink run out.
2B
Did you buy this printer new from a dealer? Doesn't sound like they're doing their job very well.
If versaworks is showing an "!" mark in the ink levels....this only means it's under 50%. If you look closely you'll notice there are only 4 levels...so once it drops below 50% the exclamation appears. If you want a more accurate measurement, on your printer go to menu/ink (something - i forget what they call it) and it will display in 10% increments if I remember correctly.
As for high quality mode - it will INCREASE ink consumption, and DECREASE the print speed.
This
also remember the more ink you lay the longer it will take for the print to dry...
