no rip and print
Discussion in 'Flexi' started by ExtremeGFX, Sep 18, 2012.
  1. ExtremeGFX
    ExtremeGFX New Member
    20
    im running flexi 8.1 with a mutoh falcon outdoor i get the print server hooked up and if i click test print it works good but if i try to rip and print a job nothing happens. I can click the send button but it never shows up in production manager. I know its something simple any ideas?
  2. rjssigns
    rjssigns Premium Subscriber
    4,463
    282
    83
    Jun 4, 2007
    Home Office
    Similar issue with our Summa cutter. Ended up the TSP/IP box got checked. (won't work with serial connection) Unchecked it and it works fine now.
  3. Flame
    Flame Major Contributor
    8,283
    6
    38
    Apr 26, 2006
    Vancouver
    If it doesn't show up in Production manager then it's something in Flexi. Do you have the Falcon setup as a printer in production manager?
  4. ExtremeGFX
    20
    figured it out flexi is not compatible with windows 7 turned on compatibly mode for xp and its good thanks for the replies i wish the search worked a little better so i wouldnt have to ask questions that have been answered a million times already
  5. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    ExtrmeGFX, as you can see from the replies you received, HELP is only a question away. There are several forums within signs101 where you can search and post. Be patient and continue to use this awesome forum.
