Not sure what to use ? Please help
what the
Owner/op
I have a customer that wants a clear acylic signs with the print graphics on the back, backed with white- The only media I am adapted to is static cling to get the reverse - Can anyone recommend what they use to achieve this print or sign process?
Thank you so much!
jtinker
Owner
You'd need a face mount film. You mount the face mount like an over laminate and then mount that on the board with the face of the print on the back of the material. Kinda like a fish bowl
henryz
Print on clear mirror apply to acrylic then apply white, if you have white print capability them do that.
AKwrapguy
Thank you so much!
Don't use static cling. Use a clear material like 3m 3650-114, reverse print, basicly laminate with white (3M 7725) and apply.
AKwrapguy
Just out of curiosity...why not just print on laminate? it's clear.....
Depends in the Laminate. 3M 8518 (gloss) is not clear but has a slight yellow tint to it. So you would have to make sure to use an optically clear lam. But I don't see why not if you have it.
ikarasu
We print on 8518 in reverse and then white back it all the time. Its not the best media to print on... You can buy ij40 in clear,.and 180 I'm clear. If your just needing to do it to one sign... Print on an overlam mirror imaged, apply it to the back... Then apply a true white vinyl to the back.
If it's something you'll do a lot... There's a few clear media's out there.
Bly
We just use our standard polymeric gloss lam - once it's backed with white it looks great.
