Nothing but numbers....?
Discussion in 'Flexi' started by aha!creative, Jun 4, 2012.
  1. aha!creative
    aha!creative Member
    39
    I normally use cutting master from Illustrator but that computer DIED this morning so I am scrambling to try to send a job from another computer that has to get done today.
    I have the art in Flexi...
    Then send it to cut...
    Then it opens in Production Manager...
    Then it sends to my Graphtec...
    Then the pen goes nuts cutting numbers, digits, etc... in a long line along the punch marks.
    What is happening!!!
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    check to make sure you have the correct driver settings.
  3. aha!creative
    aha!creative Member
    39
    I have reviewed them and they seem correct, any specific suggestions Techman?
  4. signage
    signage Major Contributor
    9,234
    30
    48
    Oct 5, 2005
    Penn
    What language is the plotter set for. If my memory is correct cut master requires Graphtec language (GPGL) and Flexi requires HPGL.
  5. TwoNine
    TwoNine Active Member
    537
    2
    I don't know if it's the language that is a problem - cause your plotter is cutting actual digits. I'd look at baud rate and transfer and packet sizes. They need to match your plotters requirements. My guess is it's trying to send too much data at once and overloading the plotter. ?? Maybe. :|
    -Chad
  6. bob
    bob Major Contributor
    5,208
    295
    83
    Nov 4, 2005
    earth
    It's HPGL vs. GPGL. Set the right one for your circumstances and this should go away.
    It's been a few years but what happens is that the serial command stream, which is all in ASCII, somewhere contains a label instruction, LB in HPGL if memory serves, bog knows what in GPGL, and from that point all of the ASCII is interpreted as label characters until a label terminator, usually EOL, EOT, or something like that, is encountered.
    Hence the seemingly endless stream of characters being plotted.
  7. aha!creative
    aha!creative Member
    39
    Thank you for all the responses! You guys rock. :)
