I've had this 20" plotter since '94 and it started making a different noise when cutting when the blade returned in the direction of the control panel.
At first it was just the different noise and it still cut okay, but then gradually it would mess up with the cut, as far as alignment of letters, sometimes skipping and not having correct spacing between letters.
Then it got even worse and when it would return to cut the inside of a letter, such as an 'O' or 'A' etc, it would cut it in the wrong place, away from where it should be. The 'different sound' it made when returning toward the control panel was even worse sounding than before.
Then as luck would have it, I got an order for an exceptionally large amount of small lettering for interior signs, and it turned into a lengthy nightmare just to finish the job, since I had to piece it together due to improper spacing between words. It also wasted a lot of vinyl.
Another vinyl guy said that it could be corrupted software so I used another old computer that had the Flexicut on it, but it did the same thing. Then I noticed how the parallel cord was at an angle against the wall, bent into a 90 degree and thought maybe one of the wires had lost good connection.
After ordering a new 6' cable ($25 + shipping) it started cutting okay again on some small jobs and I thought my problem was solved.
But tonight when I made a run of 4' in length, it did okay except for the last of the letters to be cut, then progressively got worse, until finally I was cutting one letter at a time just to be able to finish the job and manage to get paid.
So I'm thinking that once it warms up that possibly some internal electronic part is failing....beats me. I do have the original instruction book that came with it but don't have the software floppies for Flexicut. Do the dongle keys fail after so long a time?
Any suggestions would truly be appreciated as I simply don't have the money this time of year to buy another plotter, although I've certainly got my money's worth out of this one. It's been a great machine.
