One print head is not working, need help
prinT2017
New to wide format printing-
I'm having an issue with one of two print heads (epson dx7) on our wide format eco-solvent printer. I've ran plenty of head status test prints and numerous cleans, but print head 1 will not print or even clear out the head during clean cycles. While running a fill ink to purge, the ink in the tubes does not move or flow into the dampers. While pulling ink into dampers I've noticed some suction pressure. I've swapped the heads with print head 2 and found that this has only been happening on print head 1 position. Could this be result from a bad data strip, clogged tubes or dampers? Any suggestions would be helpful-
Thx
DD
prinT2017
The pump can draw solution that has been manually applied to cap sponge. I've been checking the cap top for signs of leakage and plan to switch out caps. When I switched out print heads, the print head works fine in print head 2 position. It's just been not firing in print head 1.
