Suggestions Opos will not find cut square in calibration menu
Aaron Dixon
I am trying to calibrate my Opos on an older cutter. It is a summa durasign T-140. When i try to calibrate opos on black vinyl it will cut a square, instruct to weed the square, then says press menu button. It tries to find the square by moving the vinyl forward and backward but not left to right. The displacement of the OPOS from the knife tip is approximately 1.75 inches. While setting up to cut a printed sticker I follow the directions on the cutter display screen. Set OPOS directly over the top of the black square... It finds it and the other 3.... When it cuts, it is about 2 inches to the left of where it should be. Any suggestions on how to fix this?
