Need Help Orientation of GSx Plus job and Graphix Advantage 6.0ah screen different.
jyouells
I'm rebuilding, on new old hardware, a Gerber GA 6.0 ah and GSXplus vinyl cutter. I have Graphix Advantage 6.0 installed, running and cutting on a win98se system. My problem is that the screen orientation of the design and the GSX plus are different by 90 degrees. I can axis swap to get the GSX plus to cut, but the screen and the cutter are still 90 degrees off. Am I missing a setting in Graphix Advantage? I can even edit the ini file for GS.exe to do the axis swap automatically but that still doesn't correct the 90 degree difference. Can anyone help?
Jay
