Overspray Roland VP-300
bovegas
Is there any way I can lower print heads on VP-300. Heads are a little high and there is overspray. In a manual it says hight is fixed. Wondering if any of you guys head same problem
rjssigns
Overspray = clean the encoder strip.
I use a clean microfiber cloth. If you've never done it you'll be amazed at the filth that comes off.
bovegas
I already cleaned encoder. Problem is that heads are very high, and sometime because of electro static on media, there is overspray. Lowering the head will definitely help a lot. I dont know is it posiblle
Sign Works
Fixed head cannot be lowered, try reducing static. Are you sure static is the culprit? Are you experiencing overspray with all colors?
Ragnabrok
lowering the head would botch the biderectional adjustment, possibly to past a point it could be adjusted for. A picture of the overspray and from a test print int he cleaning menu would show if it's static overspray or nozzle deflection.
bovegas
I don't understand why they didn't make adjustable head height like on vp-540. On this printer it's on high setting fixed. Print quality is not even close like on my SC_545ex on lower settings
Ragnabrok
it should be fixed at what medium would be on the SC-545, which is 2.2mm. The sc-545 and its kin also had a low, i forget that measurement.
