Painted block wall wrap - Envision or IJ180? or other? tools?
jtiii
Beautiful day, great to be alive!
I PROMISE I searched and read threads to try to figure this out - which would you recommend? This is my first wall wrap. I'm planning on buying the 2 handed 3M heat gun roller insanity, any other tools needed?
jtiii
Also, for a wall with this much texture, do y'all like gloss or matte laminate better?
Dan360
We use 480 for textured walls. I wouldn't worry much about which laminate, when applied properly, the gloss becomes quite matte. Use a lot of force and go quite slowly, there's not a huge gap between heating the film too much and not heating it enough in my experience.
We usually only put the stuff on unpainted brick, I would make sure the heat doesn't affect the paint before applying it.
Jayefkay531
For the most part Dan360 is spot on. Use 3M's 480mC, but the laminate is just as important. Definitely go with the 8548G that is recommended with it. We do painted block walls all the time, including inside our own building. Go very slow, about 3"/second, with your heat and overlap just as you would with any wall installation. As Dan mentioned, the gloss finish becomes much more of a luster if done correctly. Work from the inside out and never trap yourself in the mortar channels.
Good luck!
jtiii
Thanks for the advice! What do you mean by this?
Also, "work from the inside out" - the instructional video shows the whole "seal three sides, work towards the fourth" thing. Do you do something different?
Modern Ink Signs
You quickly tack the top/bottom/and 1 side
Then work from top to bottom
I assume the trapping mentioned is if you work your application improperly and close off a mortar joint. With proper installation techniques you should NEVER have this happen
FYI....
We use 480 w/ 8548G lam
Jayefkay531
I don't use the 2 handed heat gun roller, so my installation method is slightly different. With 480, I actually peel the entire sheet and use a paper towel to "squeegie" everything down. This basically holds it in place until you go back with a torch/heat gun and roll everything out with a soft rolly pro. This is why I start in the middle and work my way out. ModernInkSigns had it spot on - don't close off any mortar joints until all the air has been pushed out of it. With proper technique, this will never happen.
Best of luck!
AKwrapguy
We use a heat gun and rolly pro rather than the heat gun roller handle contraption. If you've got deep mortar joints maybe go with a softer roller. I've found that the biggest issue is speed. May sure you go to fast or too slow, once you get that do you'll be fine.
Bly
After doing a couple of walls with a Rollepro we finally got a 3M textured wall applicator.
That made a big difference in the speed you can get these jobs done.
Still slow af but faster and you don't burn your hands on the heat gun tip as much.
images
Modern Ink Signs
Does the Rollie-pro foam take the the heat required for proper install? 1000 degrees on the heat gun quickly melts my rollie-pro foam rollers!
I only use my Rollie-pros on rivets and some other lightly textured stuff but never for wall installs
jtiii
They make a high temp replacement roller.
