Pinch-Grit Rollers Leaving Tracks On 540XC
Discussion in 'Roland' started by quikseps, Apr 12, 2007.
  1. quikseps
    quikseps Member
    151
    Was breaking in my new 540-XC and am noticing "grit pattern track marks" on the vinyl where the pinch rollers make contact with the vinyl. Is this normal? I can actually see fairly pronounced tracks embossed with the pattern from the lower grit rollers on the vinyl.
  2. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,770
    53
    48
    Feb 27, 2007
    World
    I'm not sure what a 540-XC is, but if it's a cutting plotter it's normal to see track marks on the 2 end pinch rollers. On our cutter you can ajust the tension....
  3. quikseps
    quikseps Member
    151
    The printer is a new Roland SolJet Pro III XC-540 which is a printer/cutter. I don't believe the tension can be adjusted. When I have 54" vinyl loaded into this, we have 7 pinch roller tracks in the film with the pattern of the lower grit rollers in them. Just wondering if this is normal.
  4. ChicagoGraphics
    4,770
    53
    48
    Feb 27, 2007
    World
    No its not normal, But then again I'm not sure with the Rolands. Theres only have 7 pinch rollers on a Roland printer
  5. Baz
    Baz Very Active Member
    My SC-500 has 4 pinch rollers and i recently tried MacTac's new line of digital print media and it did leave noticeable marks where the middle rollers are located. This has not hapened to me on other medias so i suspect maybee your prob is with the type of material you are printing on. Try something else, another brand. If it does it on all materials i would contact your service rep since i am sure it is not supposed to leave any marks like you are describing.
  6. Kev41
    Kev41 Member
    37
    Mar 30, 2007
    Hello
    High temp can cause the problem depends on the vinyl you are using, might be worth trying to lower the temp & see what results you get
    Kev
  7. quikseps
    quikseps Member
    151
    This is happening on a few different Oracal calendared vinyls...which is all I have here at the moment. My preheat and print heat settings are 94 degrees and the dryer heat is set to 122 degrees...Roland recommended settings.
  8. ChicagoGraphics
    4,770
    53
    48
    Feb 27, 2007
    World
    WOW........you need that much heat on a Roland?
  9. javila
    javila Active Member
    843
    I noticed this on our 545EX in the beginning. It happened on some media (cheap media), on the orajet it was hardly noticable. Now I don't ever see it.
  10. quikseps
    quikseps Member
    151
    Possibly the vinyl is too warm when it gets whipped back into the printer for cutting....I'm going to try turning the heat completely off and see what occurs.
  11. ChicagoGraphics
    4,770
    53
    48
    Feb 27, 2007
    World
    Dont turn it completely off, it wont dry, may not even print right
  12. quikseps
    quikseps Member
    151
    I was thinking about only turning off the post printing dryer heat...not turning off the pre or print heating....they're only 94 degrees or so which is nothing.
    Tomorrow's another day....I'll post the outcome of a few experiments this weekend. Going to pick up some different vinyls and play with the heater settings.
    This was one super expensive printer that a ton of guys have, and love so I'm sure there's a solution.
    Steve
  13. james2
    james2 Member
    384
    Let us know what happens.
    I have had that occur on my Pro 3 as well, even on banner material.
    does not happen all the time.
  14. cinemasign.grafix
    cinemasign.grafix Member
    469
    Aug 14, 2005
    Have not checked out the XC . Are the pinch rollers removable? The only time I use all the rollers on my SP540 is for banner.
  15. mediaman
    mediaman Member
    319
    Steve,
    I sent you an email with details but you can move the inside rollers away from the silver marks on the roller carraige and they won't come down when the medial clamp lever is lowered. As mentioned, only use the inside rollers for banner or canvas and don't rewind the material until the ink is dry so the roller don't smear heavy ink loads.
  16. quikseps
    quikseps Member
    151
    Well...turns out I only need the two outside rollers when running vinyl so that eliminates the problem of track marks running up the center. I thought I needed at least one additional pinch roller tracking near the middle...guess not.
    Regardless, there's no way around these marks on vinyl (I guess) so I won't be running any additonal pinch rollers. I was assured by my rep this doesn't occur on banner materials where I'd want to employ additional pinch rollers.
    Have yet to run any banner material yet on this machine.
  17. cinemasign.grafix
    469
    Aug 14, 2005
    That's what I was getting at. You only need the Ext. rollers for vinyl . You'll want to add the others for banner & material that tends to tunnel.
