Plastic razor scrapers
GVP
Greetings all!
Big fan of the little plastic razor blades for removing vinyl, but not a big fan of the handles. So far, every handle we've had has broken in some way - they all seem too flimsy. So does anyone have a recommendation of a handle that's durable and will take the plastic blades?
TIA
ams
Yes, I found some amazing metal ones that work with either steel or plastic blades. Also has a non-slip grip. Let me remember where I bought them....
Texas_Signmaker
Very Active Signmaker
This is what I use... gives good leverage. You can get them at auto parts stores.
BobM
In a weak moment I purchased wooden scraper handle from Yellow tools. It came with 4 - 2"X3" orange plastic blades.
About $35 I think. It has been great. The wooden handle fits your palm, the blade is hard enough to do a good job without hurting your hand, and I'm still on my original blade after about 6 months. Stripped some tough, , cracked, cheap vinyl and some paint protective film off a six year old car.
Expensive but very durable.
equippaint
We buy the holders on amazon, spend more for a good brand, they all look the same but they aren't. All my guys like the fold up type that swings out from the side, they seem to have the best angle. The cheap ones though, wont stay locked out. Those harbor fright ones have an aggressive angle and are too short to ever get a good enough grip without scraping the skin off your knuckles. The long ones that tx showed area in between the two styles angle wise but we break them in a couple days. IMO the plastic razor blades are totally worthless unless you're charging by the hour.
ams
Are you trying to break a weld with one? I mean how much pressure are you trying to use? Scrapping should be easy and only firm pressure. I've never had an issue with the angle.
equippaint
We employ raped apes to remove decals before sandblasting
DerbyCitySignGuy
I've never used anything from YelloTools that wasn't good to great. Even when I'm thinking, "Why would I ever need this?" I always end up being pleasantly surprised.
d fleming
We have one as well. Thought it was a bit pricey but it is a great tool.
