Plotter Stops
Silverado
I'm running CASmate Pro 6.52 with Windows 98. Plotter was working fine then one day (a few months back) it quit completing the entire cut!
Any suggestions?
Thanks!!!:help:
Silverado
IAN... Cables are new. I'll check on running the TEST plot.
Gerald...It does work. Plotter stops just BEFORE completing the cut.
Ian Stewart-Koster
Older Greyer Brushie
Maybe the item's outline boundaries are just outside what the plotter thinks the material width (or length) is. Try & plot a small item.
P.S. what model of plotter is it?
Silverado
Hey IAN... It WORKED!!!!!. I reset the boundaries and everything is fine.
Thank You - Thank You - Thank You!!!
Roger
