Question PNC1100 blade protection strip
BertFromBelgium
Hi,
I've recently acquired a very beaten-up CAMM-1 PNC1100.
The blade holder was replaced by one that could not be adjusted... and cut too deep.
This has destroyed the nylon (or is it teflon?) blade protection strip.
So... I'm trying to find a replacement but everything I could find is too wide.
If my measurements are correct the strip is 3mm wide, 0.8mm thick and about 73cm long.
If I get a wider one, for example 8mm, would it be possible properly narrow it down to 3mm?
Any ideas?
Thanks!
