Prepping alupanel, DiBond, etc. for painting?
threeputt
We generally use a Scotchbrite pad or similar to scuff the surface of these panels. Then prep with Rapid Prep.
But I've noticed that the paint is not always as bonded as I'd like. What do others do here? I'd like to top coat in Bulletin enamel.
Is a primer necessary? Hopefully the painted panel is "primer" enough.
Painting experts?
Are you spraying or rolling ?? And what size panels and how many at once of the same color ??
Craig Sjoquist
Scuffs with 400 grit, cleans starts painting.
But this was mention in another forum that panel maybe powder coated & this does not work, so this question is what brand ya using ?
I get mine from N. Glanze & the least expensive
Pat Whatley
What they said...scuff with 400, clean, paint. Usually I clean them with denatured alcohol....mainly because it's the only cleaner on the table so it's easiest to reach.
If we were spraying, I'd do the 400 grit, but the amount of paint going down with a roller..... 220 grit should do just fine. Just be sure to tack it afterwards. I'd still give it as thin a coat possible with a roller.
ddarlak
Go Bills!
i roller coat with foam rollers and use ronan bulletin paint, scuff with a 3M scotchpad and still have had the paint come off in sheets, so i say sandblast the carp out of it......j/k
sand it for sure, scotchpad has failed for me a time or two....
