Print/Lam/Cut with missing rear crops
Acee76
Hi guys,
I have some large decals for vehicle signage that I have Printed and Laminated However I have just realised after squaring off the ends after Laminating that I have accidentally trimmed off and misplaced the rear crops and need to run it back through Versaworks to Contour cut the graphics. Rookie error, I know, HA!
Am I still able to run it through for Cutcontour without the rear crops somehow? Or should I try lining up the front crops and run the rip file as a cut only file and hope it cuts where its supposed to? Its only a 2 metre long job on a Roland SP540V, but I am hoping someone out there has done this before and can help out.
Thanks in advance guys.
woolly
Hi guys,
got the T shirt
the main problem is you will run out of material at the end and uncover the rear media eye although the pinch rollers may still be on the material. tag a post it note in the right position to fool it.
draw a line across the media just touching the marks line that up with the bed, set up as normal using the arrow keys position the knife tip over the tip of the first mark tick, press new origin
re rip the file as cut only with no marks and send . worth a shot as its a bin job already.
unfortunately no compensation will be applied so cut may be a bit out,
rjssigns
Just a thought...
Tape on a piece of vinyl to replace whats missing.
Measure horiz/vert distance between existing crop marks.
Make new crop marks and place in correct location.
Acee76
Thanks for the suggestions guys. I'll give it a go and cross my fingers.
Really Appreciate the help though.
