Print to Plot Issues. Mimaki Summa
im running a mimake jv3 160 sp. I have a suumacut d140 set up as well to cut. I should be able to print an image with a contour cutline. I set this up and i can see it. It shows the registration dots. But when i print, it prints only the registration dots??!!
What am i doing wrong? :banghead:
Terremoto
As far as I can tell you're not doing anything wrong. The Summa should be able to follow your CutContour line even though you can't see it.
If it does print then you did do something wrong.
Dan
rjssigns
The color for a contour cut should never print, ever. It is a color that the RIP recognizes as the place to cut.
