Printable vinyl for glass
Kustom X
Looking for a long term opaque white printable vinyl with great tack, minimal shrinkage, and clear adhesive for some logos that will be on glass doors.
Modern Ink Signs
That is a calandered vinyl. Cast will give you minimal shrinking but most have gray adhesive. Look at your product bulletins for adhesive type
shoresigns
We would use Avery 2920 for that.
Yes, I'm aware of that, but it's high end as far as calendered vinyl goes, and in our experience it doesn't shrink much when used for print/cut logos on exterior glass. Also, we typically laminate it with Avery 2080.
However, we don't get many clients who care about white vs. light grey adhesive, so most often we use 2923EZ, which is the same thing but with grey blockout adhesive and air release.
pinkiss
simple cheap glazed or etch effect vinyl should be fine if doing large stuff like doors or windows, think issue is when its exposed to outside, or high humidity then you need to seal it properly.
Yes, it might help to know if these graphics are gonna be on interior/exterior doors, reverse and whatnot.
