Printing multiple layers on vj628x?
Deejay45
total rookie here looking for any type of help or advice I may get. I have a vj628x mutoh printer and would like to print multiple ink layers onto my media. I understand I cannot print and then pass the media through the machine again, so is there a way to print 2-3 layers at once ? Without getting too confusing what I’d like to do is reverse print an image onto transparent vinyl so that I have a front mounted sticker for inside a storefront window. I would like to lay a white layer of ink on top of that reverse printed image with maybe some small text so you can see the small text from inside the store, but from outside you see the reverse printed image. Please any suggestions would help.
Boosee
yes you can in flexi. there is an option to choose how many passes you want. it is defaulted to 1 but will go up to 10 i believe. It is the 4th tab over in the job properties when you are setting up the job in production manager.
Deejay45
Thank you very much. I’m sure I can download flexi I believe it comes with my machine , I did get started with LXI though, I hear they’re similar so I’ll try that out on the Lxi and if no luck I’ll just go install the flexi, thanks again.
