Printing not to scale
Discussion in 'Flexi' started by thirty6, Jun 5, 2012.
  1. thirty6
    thirty6 New Member
    14
    Hi All , sorry if this has been asked before but i cannot find it listed, I have created a graphic in illustrator to the correct dimensions (29.6 x 37.4 cm) but when i click rip and print the size panel shows the dimensions as (30.14 x 38.00 cm).
    If I select all in flexi it shows the correct dimensions.
    Any ideas??
    Matthew
  2. jayhawksigns
    jayhawksigns Very Active Member
    1,205
    33
    48
    Jan 8, 2005
    Kansas
    Sounds like you might have a panel margin set. Check the second tab in the rip window, it'll be the entry field next to the box with four arrows pointing outward.
  3. CS-SignSupply
    CS-SignSupply Very Active Member
    +1
  4. thirty6
    thirty6 New Member
    14
    Words cannot express the pleasure you have brought to my afternoon.
    Thank you, thank you
  5. swirls
    swirls New Member
    20
    May 31, 2012
    Jamaica
    Hello.
    Did you get this issue fixed? If so, please let me know what you did.
