Printing on chrome vinyl with edge printer
bigben
I do not have the material in stock. But I was wondering if I print a spot color on chrome vinyl with my edge, do I will see the mirror effect thru the spot color? Or do I must use a translucent foil to achieve this effect?
Drip Dry
I've only printed on reflective. I needed to use translucent to achieve the effect.
So I would think you would need to use translucent and I'm not sure of the result you would get
artofacks1
Depends if the foil you use is opaque or transparent.
