Printing on reflective vinyl with non-transparent foil. Yes? No? Maybe?
RG
I have a few small print jobs for reflective vinyl and would rather not buy transparent foil. Just wondering if anyone here has successfully used non-transparent foil with an Edge printer to print on white Oralite 5700 reflective vinyl? I an using intense red and bright blue. I did a little test print and to me it looks OK at night, but I've been wrong before. Also, is the white Oralite 5700 vinyl inkjet printable? Either way, I plan to laminate the decals. Thanks!
jfiscus
Rap Master
You can print any foil onto any vinyl that will run through it. Some foils are semi-translucent an will allow reflectivity and others wont.
  • Agree
Reactions: RG
Modern Ink Signs
Yes you can
You loose light reflection debending on the opacity of the foil. if you had transparent foil the color will shift given the white point of reflective vinyl
Billct2
As the others said Yes, I've done it many times, but if you are looking for the same effect as Transparent foils it will vary greatly with the color and never have quite the same look at night
Mike Paul
Super Active Member
Unless you don't stock them use your transparent CMYK foils, no need to purchase transparent spot colors...
