Printing Outlines on the bed of a Flatbed Printer
Lilukey1
I have the JFX200-2513. Im trying to find a way to print outlines on my bed without having to print directly on my bed. I need the vacuum to hold down my substrate. Printing outlines on my bed is clogging up the vacuum holes which then takes a while to unclog. Any recommendations?
StarSign
Thin pattern paper works, cover the table print the pattern the paper is thing enough for their to still form a vacuum to hold down your material.
Lilukey1
I've tried using paper it tends to raise up higher than the substrate in some parts. The head then ends up rubbing the paper.
Modern Ink Signs
We print outlines all the time on ours. A few clogged holes should not affect the vacuum pressure. Add scrap material of a thinkness around your print job. This will help the vacuum pressure for smaller objects.
We clean our table with a sharp single edge razor blade and the head cleaner. If needed we poke out the holes with a dental pick.
Razor blade does not scratch the table btw if done right
Just putting it out there. To each his own how they want to do things
Lilukey1
Thank You great information.
L.D
I have a customer that uses clear application tape. They lay the tape down, print outlines on it and then cut the outlines out with a exacto knife. Seems to work pretty well.
Ukeyone
The ADA Guy
We lay transfer tape down when we need paper jigs. It works really well and you can use it many times before replacing.
