problem with print blue SP540v
Discussion in 'Roland' started by ljpro, Sep 4, 2013.
  1. ljpro
    ljpro New Member
    10
    Sep 3, 2013
    slovakia
  2. rjssigns
    rjssigns Major Contributor
    5,164
    521
    113
    Jun 4, 2007
    Home Office
    Was the printer not used for a time? May need to pull ink through heads or a head soak or both.
  3. ljpro
    ljpro New Member
    10
    Sep 3, 2013
    slovakia
    one day without print.
    one day without electric and without print, and this problem. It is possible?
  4. brush1
    brush1 Member
    287
    Change cyan cartridge and run regular cleaning.
    Try test again.
  5. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    CLEAN, CLEAN, then CLEAN again....my black did this last week....
  6. ljpro
    ljpro New Member
    10
    Sep 3, 2013
    slovakia
    i clean heads with powerfull cleaning 3x. I wash head on clearing watter and nothing:(
    cartridge changed and no change.
    Wrong head, maybe
  7. jfiscus
    jfiscus Map Wraster
    3,193
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    post a bigger picture
  8. brush1
    brush1 Member
    287
    Why you did power cleaning?
    Check damper, tubing for ink flow (maybe air), pump and tubing in the waste bottle (it may be cloged).
    It looks like ink is not going to the head.
  9. ljpro
    ljpro New Member
    10
    Sep 3, 2013
    slovakia
  10. DRamm76
    DRamm76 Member
    496
    1
    Cleaning, Calibrating and even clean the encoder strip as well.
  11. jfiscus
    jfiscus Map Wraster
    3,193
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    heads look like they've been thoroughly well used, so there *may* be no ever returning to normal. I would try parking the head on the capping station and syringing or a small vacuum pump to draw ink through the head. A head soak may help also. Not sure if either of these will work though after seeing the pattern, as the black looks good while the cyan looks like hell.
