Need Help Problems with Gerber Edge
BullDog613
I have an old Gerber Edge 1 with an HS15plus plotter and my computer with Window 8 had a motherboard go out. I've updated the computer to Windows 10 and now in the plot manager I can't access the com and lpt ports so the computer won't talk to the printer and plotter.
I have another computer that I updated to Window 10 and it has an HS15plus plotter that works because in the plot manger I am able to select the com3 port.
I am using the Gerber Serial to usb and parallel to usb cords.
I've called Gerber Tech support and they have not gotten back to me for 2 weeks after numerous calls. Any body have and ideas how to fix this?
netsol
there are a number of things you need to do.
all the settings under device manager>ports>your com port>advanced have to match
ie: 38000. one one odd xon/xoff (example, not the settings you should use
serial is not plug & play, settings must match
parallel port, mode must be corrrect bidirectional/epp/ecp. (i forget which one works)
normally if printer port doesn't work, i just use a $50. startec parallel print server on amazon.
for the serial port, download user manual for the hs15, make sure your port in device manager matches what the plotter is set for
BullDog613
Thanks, I'll try some of these things.
