Quick Coroplast Question
neato
For 18 x 24 4mm Coroplast signs that will hang on a light pole, would you have the flutes run vertically or horizontally?
Locals Find!
I would run them vertically if they are mounted only from the top & bottom, and horizontally if they are going to be mounted from the side.
The reason I say this is if the wind load is hitting them while they are mounted on the side a vertical flute is likely to give and bend. Whereas the horizontal flute will give resistance.
If they are mounted from the top and bottom you want the flutes vertical to both provide resistance against the wind and to allow water to drain.
Mr. Sign Pro
We do a bunch of these for short term parking. These are for a specific customer and they always specify horizontal flutes so the sign doesn't wrap around the pole when it gets windy. They say horizontal flutes work much better than vertical flutes.
bob
Flutes perpendicular to the way you don't want the sign to bend or that it's likely to bend. Always.
Considering what the pole is made of and it's shape..... you might wanna build a metal frame for the temporary sign and weld it fast to the pole and fasten the sign to your frame. If it's a wooden pole, around here, it's still illegal to attach any sign to it.
:thumb:
So, if you put the sign up one way, the holes will drain..... how cleverly thoughtful. :rolleyes: I guess if you put the sign up with the flutes running the way water cannot drain, how does the water get in there in the first place ?? Does that mean bees and other flying insects can build nests in those thar flutes ?? I still haven't seen ANYONE try to play the flutes in a Cor-X sign. If you do, take a picture and post it....... :thankyou:
If you don't want them to bend horizontal. As was mentioned they will bend if the pole is vertical and the flutes are vertical. Interesting how many missed on this one...
tattoo.dan
we cut footbal helmets out of coro to be screwed to telephone poles. run flute horizontal so they resist the wind better and won't wrap around the pole
