Rasterlink/Mimaki JV33 stops in the middle of print with no error
philipjk108
Hello, my printer is a Mimaki JV33-130 and I use RasterLink5SG as my RIP software. 3-4 times a day it will just stop in the middle of a print but there will be no error message, and everything on the printer and rasterlink makes it look like it should still be printing. I would appreciate any help at all, and if you need anymore info about my set-up just let me know and I will answer ASAP.
-Thanks, Philip
Textile
-Thanks, Philip
Make sure you have the latest firmware update!
First get the obvious out of the way and make sure your computer isn't falling asleep during the printing process. If it does, change your sleep settings off. Second obvious answer is change the USB cable and see if that helps at all. If those two things are working properly, you could have all sorts of issues with either the printer or the computer. Bad memory, bad USB port, main boar malfunction etc.
