Need Help Rear Window Perf w/ Spoiler
Hollywoodsigns
Designer, printer
I have run into this before, Hoping someone has an Idea.
I am doing the back window on a 2011 Nissan Rogue. This is a curved window (not a problem), but it has the spoiler that sits just above the glass and follows it. There are a lot of the smaller SUV's and Wagons that do this. How do I get the perf up under the spoiler and seal the top when it is so close?
search
Dan360
I've had a couple vans and SUVs like this. Put knifeless tape up there first. Sealing it isn't very hard, you'll just be a little cramped. I find it helps to have as little excess material as possible up there. I either kinda fold it back and away from the spoiler as I move closer to it or cut it a little whenever it starts to grab the spoiler too much.
SignMeUpGraphics
Super Active Member
We did a similar vehicle a couple of days ago. 5 bolts later the spoiler was off and we could easily clean around the entire top edge of the window, lay the perf down properly then re-install. Took maybe 10 minutes longer than a regular install.
