Roland Print Head Manifold
Discussion in 'Roland' started by VitalSignsInc, Jun 14, 2012.
  1. VitalSignsInc
    VitalSignsInc Member
    30
    Alright guys and gals. I am having the issue where one side of my Lc is dropping out of the print test so i replace both dampers pulled ink through with the syringe. Then going back to install realize the manifold nipple is broken! i can find online places that sell the manifold from $24.99 to about 89.99 is this something i can replace i read you have to pull the head. I am not crazy about that but i will do. HELP!
  2. premiercolour
    premiercolour A Mutoh, Mimaki dealer for sales and services
  3. VitalSignsInc
    30
    I just was on your website fantastic my roland guy wants to use an old one off a head they have taken out. But till then i am going to print what i can. i put back on the covers and when the machine gets turned on it instantly throws up wrong head installed :banghead:
  4. premiercolour
    old one means that this manifold was soaked with solvent ink in some time. $22.50 isn't a big investment ya? As long as it prints, that's all it counted.
  5. VitalSignsInc
    30
    gotcha well i am having all kinds of issues i just lost the whole c group which is Lc and Lm
  6. Cale Frederick
    Cale Frederick Member
    102
    Just had same thing happen on our xc540. I got a new manifold and changed it out myself... yes you do have to take the head out. Unfortunately we had more problems and still had to have a tech come spend 3 days working on the printer. Turned out to be a third party ink problem. Swelled lines and clogged 4 sets of dampers before we got it all cleaned out.
  7. Fatboy
    Fatboy Very Active Member
    My advice....get a technician
  8. VitalSignsInc
    30
    I just had a head replaced by a tech within a few weeks of this. i am fairly comfortable with the machine i have been using for over 4 yrs and have only needed one head replaced.
  9. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    OEM or 3rd party inks?
    Are you using OEM or 3rd party inks?
  10. Jack Knight1979
    Jack Knight1979 Very Active Member
    1,078
    Jan 23, 2008
    Maine
    Cale. I to would like to know who you're using.
  11. premiercolour
    Who suuplied you that third party ink? Let's spell out the bad guys.
  12. CS-SignSupply-TT
    1,541
    1
    At inks are the culprit
    Jack and Fieldcenter, in an earlier post (about :45 minutes prior), Cale identified the ink as AT INK
  13. VitalSignsInc
    30
    I am using triangle edx ink If i can prove the inks did something fellers will back it. they came here ran test on my machine with oem ink and replaced them with the triangle. i have tracked down the few problems i am having 1. the Lc head only printing half is due to the cracked manifold nipple i am recieveing a new one in the morning to replace it. 2. after seeing the error wrong print head installed i found that i had blown a head fuse (which by the way is smaller than a tic tac) f3 to be exact. i also have a new one coming in the morning.
    i would like to hear the horror stories about triangle ink specificaly. I have never heard of issues. i ran solaris ink for a 1 1/2 years before going back to oem due to the cartridges were so cheaply made they would not trigger that is was empty. Ive owned this machine 4 years replace my first head last week and last time i checked i was around 11 billion shots on my yellow.
  14. Cale Frederick
    102
    Sorry for not keeping up, busy day at work... AT Inks is the ink we are using. I actually made a separate post about the ink earlier today. It goes into more detail about what all happened. I still have 10 of their cartridges in there that are printing great. Only the cyan ones are the ones that messed up. They were from a separate batch than the other colors. I do plan on either swapping back to Roland inks as the other inks run out or maybe, just maybe try another 3rd party. Not excited about another 3rd party after this but the boss seems to want to stay 3rd party. Any other Inks that would be ok for a low - mid volume shop?
  15. CS-SignSupply-TT
    1,541
    1
    Oem vs. 3rd party plug n play
    Cale, I would encourage you to create a spreadsheet to determine the square footage you are printing on a monthly basis. Then determine the amount of ink purchased/used on a monthly basis. Finally, plug in the cost of the OEM inks instead of the 3rd party inks to determine your costs with OEM. I know it sounds like a lot of math, but your actual numbers will tell the story, OEM vs. 3rd party
  16. CS-SignSupply
    CS-SignSupply Very Active Member
    Let us know if we can help with the Roland OEM inks. We are located just outside of Atlanta, GA.
  17. Kentucky Wraps
    Kentucky Wraps Kentucky Wraps
    1,164
    51
    48
    Mar 6, 2009
    Bluegrass
  18. CS-SignSupply-TT
    1,541
    1
    3rd party vs oem
    Good day Cale, I am sorry for your troubles. Perhaps CS SignSupply can be of service to you? Please let me know how we may help.
