Roland Pro XC-540 Can get out of menu option: "Select Ink Type"
susiestrickline
Hello and Good Morning!
I have a Roland Pro III XC-540....
anyways- I'm just trying to get OUT of the blooming menu. It is saying:
"SELECT INK TYPE"
"E-SOL MAX LcLm"
It does give me an option to go to:
"E-SOL MAX CMYKMC"
But I just want to be out of this menu- I've tried the service code arrow medley- but it won't budge.
I've tried unplugging for a while... pressing every other button over and over again...
ughhhhh.... I'm almost to the point of stabbing myself in the eye!
Suggestions?
JulieS
Sounds like what I experienced last year. I was trying different things on my own to get a printhead to work and somehow started this MAJOR cleaning process that uses a ton of ink. I can't remember what it was called in the menu or what exactly it did. But I remember there was no way to back out of it. Had to SELECT INK TYPE and let it go through the process.
GTSTech_1
Not sure why, but your printer has been reset. True there is no way around the ink setup process, but you can disconnect the captop tubes from the pumps. This will save the ink in the lines. Good luck.
Just my .02
