Need Help ROLAND sp 300
KevinF
I have a Roland SP 300 that keeps blowing the F3 fuse when I plug in the servo board. I have installed new heads and have swapped cables to make sure both heads are fine. Any Ideas?
Thanks in advance
Kevin
2ny
Hi.
I once swapped the flat cables on the print heads, and the fuses on the mainboard blowed instantly.
Make sure your cables are on the correct head before you power on.
Best regards
Tony
