Roland Versacamm SP300 Question
jadrewitz
My red color is printing orange ... please help
Might be time to change your captops. If you use a syringe and drop a few drops of cleaning fluid into the cap it should flow down. If it just stays pooled at the top it’s time to change it. Also, have you run the yellow ink empty and not change the cartridge? I’ve done that and had that problem. It obviously required a new yellow cartridge and lots of head cleanings to get the ink flowing back through the head. You can also try pulling the ink through the head but that would be a last resort option. More than likely a captop, easy fix and you’ll be up and running. Hope this helps!
