Roland Vp540 Fuse
Michael Barbare
Roland VIP-540
Main power board has 3 fuses
1.3 amp
250 volt
Should both ends of the fuse have power all the time
If they don't does this mean the main board is bad
You want to test for continuity. It should be a setting on your voltmeter under the ohms category. If it beeps or a light turns on, the fuse is good. If it doesn't, it's bad.
