Question Run Roland printer with 2 or 4 Printheads
akhuzaie
Hi evryon, this is Ahmed From Bahrian.
Can anyone help with my Xj740 i would like to run the printer with 2 or 4 printheads insted of 6
Is there an option to do that
Thanx
ProPDF
You may be able to by making a profile as a VP540 configuration but I am not %100 sure. You are able to actually use orange and green inks with all soljets if you create a CMYKOG profile through the SC540 profile creation process. This can be done on Flexi 12. Caldera will allow you to use channel control as well where you can shut heads down. The problem is the cost of channel control RIPS are not worth it if you are trying to get to a solution for C bank heads not firing. When you print via ethernet you can use other profiles for your machine as long as the ip matches in Flexi 12. Good Luck.
