Sai Flexi 12
Matt39
Hi,
i have printer Mutoh 1638X with UMS ink.
looking for some profiles for flexi 12.
i have list of profiles but im not happy becouse i use Avery (3000) and Metamark(md5, md x).
this is a list with all profiles what i found.
thanks
Sent from my SM-G950F using Tapatalk
morty87
Hi,
thanks
You have more than me. The ones I have for my 1642 aren't even correct or accurate with my machine either. Not 1 of them has the heat settings correct I literally have to turn down the heat on every single one.
Boxed profiles will never be perfect for everyone especially the heat settings. These profiles are made just so you can print right after the machine is installed and if you want profiles that work for your environment, ink type and setup, you need to make them yourself.
GaSouthpaw
This^^^. All day long.
