Sawtrax Sign maker wall cutter
Having suffered the Fletcher wall cutter for to long I plan to buy the Sawtrax wall cutter with router attachment to help with Max metal lightboxes etc is this the best option or are there alternatives you use.
Currently I vend all this work
Many thanks
Johnny Best
Festool and Makita make track saws and maybe more now. The blade cuts a "v" in the material on one side so you can make a 90 degree bend without a metal brake. Very accurate cuts and a smooth finish on the edge. Great tool for cutting material and has a place to plug in shop vac to get cut pieces of metal and core debris.
Sawtrack setups are good but the tracksaw to me is more accurate in cutting.
